Which Saw to buy?
jaguar999
24 Jan 2018
Wokingham UK
Hi All,
Happy to find this forum.
I bought a new house and want to do some wood work like:
Under stair drawer
Shelving the built-in wardrobe
Custom cabinets for bathroom
Maybe a built in wardrobe if I get enough confidence.
Lader and boarding in loft.
I already have already have a jigsaw and a jigsaw table from Germany ( neutech) for cutting straight edges.
But it is not very great reliable tool.
Please advice what should I buy (on a budget)
1. MacAllister used but in pristine condition for just £28
2. Well used Makita circular saw for £50.
Will I actually need a table saw? And a router?
If you carry on this DIY route, madness goes there, =P~ but seriously you will eventually want the convenience of a table saw and router/table if you are going to make any type of stile and rail panel doors for the cupboards and wardrobes, but in the first instance a decent track saw will suffice to cut up sheet goods and the occasional cross cut, I have this cheap Rutlands one: http://www.rutlands.co.uk/sp+woodworkin ... nds+xt3516 it does what its meant for, also look at this thread: rutlands-plunge-saw-t108210.html
Mike
As the per the last advice track saw will allow you to turn sheets into components for your projects and get them
cut accurately , they are available now from many sources like screwfix and even Lidl who sell the cheapest when its available , a table saw takes a lot of space and is much more difficult to get good results on a budget .
What you will need is a sturdy flat bench/table to cut/layout/build your projects - and this would make a good first project - a torsion box type bench/table is a good example of a light but strong bench that you could adapt to your needs and would be great practice for your future projects.
Google torsion box bench for ideas.
I’d get the makita unless it really is in very bad condition, it will be much better made. Always avoid the B&Q diy machinery if you can, they build them like ice cream tubs.
I made this pretty cheaply (pics at bottom), the main section is a single sheet of 18mm ply, 1220 x 610 that I cut into 3 strips and then cut one of those in half. Cut out the centres of the edge bits, used one of those to brace the centre. That bit was £17 from B&Q. The sides are glued but the top and bottom are only screwed on so that I can replace them. After a minor cutting accident you can see where I cut the corner, I got a sheet of 25mm mdf that I can slide on top and cut into that instead of the bench. Overall it's very light indeed. I have to work outside and this is stored upstairs in a spare room. I can carry it with no problems. Storage is really useful when working on stuff. I can bring tools out and put them in there out of the way and get them as I need them.
The legs were made from bits I had but work surprisingly well. Whole thing took less than an afternoon to sort (once I'd gathered stuff together) and was made using a Titan track saw from Screwfix (£99) , a Bosch PST700E jigsaw (£40), a Ryobi one+ drill/driver (£99 - special deal included battery + charger) , oh and a Katsu trim router (£38). Screws are drywall ones (£3 for 1000).
If I were to do it again I wouldn't use a trim router and round over the cut outs I'd just knock the edges off with a sanding block. Mine are rounded over and it makes clamping things straight awkward.
I'm a total n00b at this woodworking lark, so honestly, anyone can make this easily.
Thanks you so much for all your advise.
The makita deal didnt happen.
I ended up buying a used Dewalt Dwe650 circular saw.
