Which dry grinder?
Random Orbital Bob
13 May 2011
Hampshire/Berks Border
Hi folks
I need to get a new dry grinder. Old ones ancient and died. I will be using it to shape HSS turning tools. Or perhaps even an alternative abrasive based sharpening system, I really am open minded at this stage. I have a Tormek for sharpening and am very happy with it. But not for shaping, so I may get the jig carrier and re-use my tormek jigs on whatever grinder I buy.
So whats current thinking on dry shaping of HSS tools where I want to remove a lot of metal fast?
Sorby Pro-edge is good. Very easy freehand; jigs available for the faint hearted!
Hi
Well my 'theory' is that the ceramic wheel will be fairly hard and resilient, plan to use it for profiling etc. The white aluminium oxide wheel which is softer, but wider, will be used to maintain the profile as required, the Tormek for the final edge.
Regards Mick
One of these would do the trick Rob !
It was my main sharpening system for a good long while but been getting in the way in the workshop for a while now as I have a surplus of grinders and sharpening systems ! Can't recall the grit grades on the wheels, but if you might be interested let me know and I'll take a look and let you know tomorrow.
Cheers, Paul
Random Orbital Bob":2fajnr0o said:
that Norton looks interesting
I fitted a Blue wheel from Peter Childs way back in 2005 to my cheap and cheerful grinder, it's still going strong, can't remember the last time I dressed it as it never clogs, main thing is to ensure you use only the lightest pressure on the tools as it cuts so freely and self sharpens by loosing facets off the wheel media.
Some More Links showing evolution of jig use, normally only use the blue for my scrapers and skew chisels, the white wheel (it's less aggressive than the blue) is used with a tormek jig and a home made version of the same for my round gouges.
Random Orbital Bob":3ld0qkxq said:
Hi Paul
I would be interested old sport. Do you know what the diameters of the wheels and arbors are (and what make come to think of it)
It's a Record Power 6" grinder Rob, with an O'donnelll ruby wheel I think on the left and a wider white wheel (original from Record) on the right.
No toolrests or flip down eye shields. Any use or are you after an 8" ?
Cheers, Paul
sounds great Paul. As long as the arbor diameter conforms to industry standard (so I can elect to use different wheels into the future) then it sounds fine. I'm not worried about toolrest or screen since I'll be redeploying my tormek jigs.
Also since my intention is shaping only ie a one time operation, fineness isn't an issue. This is about fast steel removal from hard (HSS) large surface area tools like skew chisels. The Tormek easily handles all the fine stuff ie sharpening and honing.
Can the Pro-edge be used a a linisher, say for flattening chisel backs, or does the mechanism interfere with placing something flat on the platten?
Hi Rob, pm sent.
Cheers, Paul
