Thanks roger, that's a start, it isn't a vibration damper though... or at least I don't think it is the black bit in the middle is a hard plastic hex nut its acting as a mount converter thingy! the course thread goes into a plastic moulding on the winder body allowing you to bolt it through a plate with the parallel stud side. I don't really want any movement once its mounted.
