woodfarmer
I have used a small angle grinder with flexible backing pad, but at 4 1/2 inches it is too big to fit into the curves, I have seen a 2 inch one from styles bad bates but are there better alternatives ?
John. B":zl40ledi said:The Simon Hope pro rotary sander. Simply the best!!!!!!!!!
John. B
John. B":20xwutys said:I also use cut abranet sheets to fit my Hope rotary sander pads as well as Rhyno abrasive.
John. B
I have found this, using the 'velcro' facility, seems OK on the hand sanding flatwork pads without damage but I think it's the increased heat and pressure it's all too easy to generate on the lathe that strips the hooks very quickly, at least it did when I tried it. Mind you it might just have been the brand of pads I was using at the time were more prone, had longer hooks or something.gregmcateer":37nq0rqr said:John. B":37nq0rqr said:I also use cut abranet sheets to fit my Hope rotary sander pads as well as Rhyno abrasive.
John. B
I'd seen talk (is that even possible :? ??) that the hook and loop gets worn down on the arbor pad, as it sticks through the abranet. I like abranet for hand sanding, but have bought some rhino from Richard Findley for power sanding.
woodfarmer":kozrfc43 said:
woodfarmer":294ky5aq said:
