Krome10
Hi folks
Another general DIY query if you don't mind.
I'm in the middle of putting up a kitchen extractor. The cooker is on an internal wall, so the ducting takes a right hand turn above the hood and runs for a meter and a half or so to the nearest outside wall. The previous hood had small rectangular ducting that exited bang in the corner there the two walls and ceiling meet. The new ducting is round and much larger at 6"/150mm diameter.
I've made the hole in the wall, but because of the previous rectangular hole I'm now left with three quarters of a nice round hole, and a quarter of a large gap where the previous hole was. I feel reasonably sure none of that make much sense, so there's plenty of pics below from inside and out. As you'll see, it's a cavity wall.
I'm guessing/thinking I'll need to fill the large gap with the ducting in place, but let me know if you think otherwise.
But more to the point what's best to use? Mortar? Expanding foam? Or???
And does it matter if I bridge the cavity seeing as it is right in the corner and the ducting bridges it anyhow?
Many thanks
Many thanks
