I've found a dye a like the appearance of but intend to use shellac on top. The problem I have is the dye is very sensitive to methylated spirit and will be disturbed leaving a sort of blotched effect.
Usually as a barrier coat I'd go for shellac, could anyone suggest an alternative? I think I could probably just use a coat of thinned oil varnish? Ive tested with white spirit and the dye is fine in contact with it.
