What spray machine??
Andycase
24 Apr 2011
Morecambe, Lancashire
Hi All
I have been making and refurbishing furniture for a little while and am thinking about getting an Airless spray machine.
I am a hobby user, so i dont do it full time.
i would like to spray emulsion, acrylic eggshell, very occasionally oil based paint, and sometimes stains perhaps.
I would also consider doing the odd room when decorsting time comes around.
I have looked online at Wagner and Earlex - i dont mind spending around £300. I have also seen one here www.localtoolsales.co.uk which is unbranded but seems to be along the same lines.
Is there anyone that has used Wagner/Earlex for spraying furniture that can say which is best?
If you can stretch a bit more I would consider one of the Fuji HVLP sprayers. I myself use the Earlex 5000 spray machine and I have had good results with it. It is quite noisy and I think a more expensive machine will have a better turbine that can handle thicker paints.
I have both HVLP (a few) and an airless Wagner Pro 117 (light trade rating). Having used them all (except the Fuji HVLP), I would say spraying furniture is not what an airless is aimed at. It doesn't offer anywhere near the amount of control over than fan size that a HVLP does - or any TBH. You can only turn the pressure down on an airless - but that may cause issues with the finish.
For furniture stick with an HVLP - an Apollo is a good starter machine and I would suspect that the Earlex would be comparable.
HIH
Dibs
