What is this?
Nicely made, clearly fixes to a frame of some kind (protruding bolt), ball joint for flexibility
so not single purpose, clearly holds a cylinder of some kind, intended to be loaded
(and unloaded) quickly (the handles and spring).
Very reminiscent of the glassware supports dimly remembered
from chemistry labs.
BugBear
Eric The Viking":2j3w27v0 said:
Some old sort of lighting clamp for small movie lights?
That double spring looks like it means business.
Good spot on the double spring. A little strong for a laboratory.
BugBear
It's reminiscent of a tool used for supporting lead pipe whilst joint wiping, there would be a pair of these fixed to a frame with the ball joint allowing alignment.
