Imagine, if you will, a length of wood 1 inch square , and say one foot in length, glued to a flat board.
A second length , also one inch square, is butted up at right angles to the first, (and will also be glued down to the board eventually) but instead of a plain butt joint, the end of the second piece is cut at , say a 30 degree angle , and a corresponding full width angled pocket/mortise/socket is cut into the first piece to receive it, going from nothing at the top to 1/2" (or whatever) at the bottom.. So looking down on the joint from the top it looks like a butt joint.
What is the technically correct name for such a joint ? I am thinking "angled housing joint", but there may well be a more correct name.
