What bowl gouge would you recommend?
YouSpinMeRightRound
31 Mar 2014
Northern Ireland
Hi everyone,
Since I got some rather helpful advice on my first thread, I thought I'd come pick some brains once more.
I want to start working on bowls, so I'll need a bowl gouge. The advice I see everywhere is to stick with HSS, so let's restrict it to that. What HSS bowl gouge would you suggest I get, and why? Are there any other tools you'd recommend for basic bowl turning?
If relevant, I'm limited to 9" diameter on my shiny new AWSL, and am unlikely to go deeper than 4" (5" at most).
While I'm waiting for the wisdom of this forum and whatever I settle on being delivered, is there any safe way I can practice with regular gouges? I mean for very shallow things, almost plates. Don't worry, you wan't have to persuade me not to do anything stupid. If the people with many more years of experience than me say it's a bad idea, I'll wait for the gouge.
To be honest the only thing to think about is size, am for something in the region of 3/8" or 1/2" initially, a decent all round size. Personally I would recommend one of the major makers e.g. Ashley Isles, Sorby, Crown etc. Record tend to have handles that are too short for my taste but the steel is good.
I cannot really recommend a bowl gouge. I have just brought a crown Elsworth one which is supposed to be brilliant but I haven't used it yet. As far as using other gouges..... Definitely not a spindle roughing gouge but the spindle detail gouge is useable as far as I know. It is much the same but not as strong so not for deep bowl use but you could play with it while you wait.
But I won't be surprised if I am contradicted on that. :)
I love using the my Sorby 3/8 bowl gouge,which i have gotta replace now,which i got with the six piece starter set,of which i still use frequently the parting tool,roughing gouge,spindle gouge.the only one i don't use very often is the skew,but my favourite bowl gouge for larger bowls is my Henry Taylor 1/2" bowl gouge and the 5/8" Woodcut replaceable tipped tool.
If you are just starting out i'd go for the Sorby six piece set and build on that as you get more experience.
Hi
I'd go for a 3/8" fingernail ground bowl gouge - my preference is for Robert Sorby gouges but I'm sure Ashley Isles would be just as good.
Other tools I think are essential when learning to bowl turn would be an 1/8", (or possibly 1/4"), parting tool, a 1/2" or 3/4" round nose scraper and a 3/4" straight scraper in that order of preference.
The scrapers could be replaced with a replaceable tip carbide scraper if that floats your boat, (I'm a bit of a traditionalist).
Edited to add: If you think you will expand your turning experience to include spindle turning as well, (silly not to :) ), you would do well to consider the Sorby six piece beginners set as suggested by Paul J - it was the set I started with and with the benefit of fifteen years experience I think it represents the most suitable beginners set available, it is also substantial saving over buying individual tools.
End of shameless plug :)
Regards Mick
Hi
I'm not sure what you mean by 'regular gouges', especially as it seems you have no turning tools at present, (sorry if I've jumped to the wrong conclusion there).
The accepted tools for bowl turning are: Bowl gouges, parting tools and scrapers - yes spindle gouges can be used for bowl turning once you understand their strength limitations however as a beginner why add another layer of complexity, stick to bowl gouges initially.
Carving gouges, chisels, old files, pointy bits of metal should never be directed at a spinning bowl blank :wink: :roll:
Regards Mick
You would do really well to join a local club, where you can usually get to try different tools and see how they feel to you. The number of different recommendations here shows that a lot comes down to personal taste and feeling. I agree that the advice here is (generally) very good, but it does differ from bod to bod, so you might end up with pricey tools that don't get a lot of use. We all have some!!
The 'normal' bowl gouges in the 3/8-1/2" range supplied under the brand names of Hamlet, Crown, Ashley Iles , Record, Sorby are what I would recommend and to avoid any with exotic grinds and celebrity marketing.
Time to consider the more exotic when you know what a standard tool can do and have developed enough knowledge to be aware of any advantages that might meet your method of working better.
One of the limitations you face is that of having to buy on-line ("awaiting to be delivered"), as mentioned by Pete the feel of a tool in your hands can influence your turning considerable (he finds crown handles too short) on the other hand I'm not very comfortable with Sorby handles and have a crown that is a go-for for certain tasks..
Picking up the various makes of 'equivalent tools' at a show is my method these days in choosing replacements, when one feels right in the hand it invariable performs better on the lathe.
As mentioned above if you can get to a club and handle a few of the tools there you may get a feel for a brand or size that feel 'right'
As you see, if ten people answer you will get ten different answers. But there is a theme to it.
As a beginner myself, although I don't have the experience and skill I do know what it is like to do battle with a bit of wood. My tool of choice is my Crown !/2" bowl gouge and the reason is it is a big strong tool that gives you confidence. It also give you lots of leverage. After a while you will find it ceases to be a battle and you then learn to use it better. At this point you will have enough technique going that a 3/8 gouge would work well for you in the sizes you envisage using. but starting off on the first few cuts on a rough blank you do need an "edge" in more ways than one.
As important as the tool you want to choose your wood carefully and select something that cuts and turns easily. Green pear, sycamore etc. it will help you to learn how to present the tool and to get a feel for it. You also stand a better chance of learning how the tool should cut and when to resharpen it.
Hope that helps.....
Whatever Bowl gouge you eventually choose you will no doubt have a few catches. Its all part of the learning curve. Spending a few hours watching you tube videos of experts turning bowl before you even pick up a tool can be time well spent. Like many in these forums I am a beginner but would agree with 1/2" bowl gouge as a good starting point. The main thing is go for a recognized name and get the best you can afford as it will pay you back many times over in the long run.
Hi
I think the size of the bowl gouge should be matched to the OP's choice of lathe - in this case I'd consider a 1/2" bowl gouge as being OTT.
Regards Mick
Spindle":zhxuhrq5 said:
Hi
Regards Mick
A 1/2" bowl gouge is fine for bowls of most sizes that can be turned on his lathe, large or small. If I had tools that matched the lathe I would end up with three sets of tools. The main problem would be if he bought a small one e.g. 1/4" or less. As a beginner he is almost bound to get catches and safety wise there is a need to have a gouge that has a decent sized shank. The thing that makes the main difference is the style of grind and that is something that will be found with experience and practice as with the type of handle. Where possible I usually buy unhandled tools and put my own grind on them for example but that is not something that perhaps a beginner would or should be doing. Joining a club if possible and seeing what is available would be ideal.
A word of caution when referring to 3/8" versus 1/2" bowl gouges, dependent upon brand and which catalogue you are looking at, the means of cataloguing the size may differ.
Some brands use the round stock diameter to rate size.
Others use the distance across the top of the flute.
Therefore a 1/2" round stock with a 3/8" flute may have two differing size ratings dependent upon brand.
Five out of my six regular use round gouges are 1/2" stock, the other is 3/8" stock (or metric equivalents), I would go along with the suggestion by Mick to err on the smaller sizes (I.E. don't buy a 1/2" flute, 5/8" stock) gouge.
I got the Axminster set, currently £75. Having said that there is a school of thought that says don't buy a set because you get tools you don't need. I've added others as a go eg Ellsworth and I don't use some of the Axi set, but have re-shaped some of them for specific little jobs.
Brian
Yep, its worth remembering that tools can be reshaped. I was looking at skews the other day and there was one that was 1.25 inches and shaped to a curve to make its use 'safer and better' I was quite tempted but a similar sized skew without the shaping was less than half the price and the curve us easy enough to do on any form of grinder.
From asking a similar question back in 2011, I opted for a superflute. It It is the only bowl gouge I have and have yet to feel the need to purchase another. It works fine for everything I do bowl wise from small to large and referring to the comments earlier made, it does also feel 'good' in the hand, which I think also gives one confidence.
Random Orbital Bob":3uu5c9dh said:
Safety wise. Don't use a spindle gouge on a bowl. Tang versus solid shaft inside the handle can cause tool to snap with catches.
The only spindle gouge with a tang (apart from really old ones) that I have come across is a roughing gouge. I agree that using any tanged gouge with a long overhang is potentially dangerous though.
