Wanted: Small router
Dan-K
30 Jan 2010
Staplehurst, Kent
Hi guys,
I have a Leigh dovetail jig I plan to give my brother, who is hopefully starting a carpentry apprenticeship soon. The jig is not too much use on its own so I'm looking for a 1/4" or 8mm router. I can't afford to spend 80 notes on a new T4 or similar, so I was wondering if anyone has either suggestions for a cheap but good (easily controllable) small router, or possibly an old router gathering dust in the shop that could be purchased for not much wonga :oops:
Thanks for any suggestions :)
I find that the larger cutters with 1/4" shanks chatter and cut oversize so go for a router that will take 8mm bits
Jason
I'd actually suggest going for a 1/2 inch router with plenty of power (and use the relevant collet). You take a lot of stock at once with dovetail jigs and im not fully convinced something like a T4 would handle it.
Having said that ive never tried it with a T4 either, so if someone else has please correct me
Luke
I've done dovetails with an Akeda/Trend jig and a T4, but the latter is a horrible piece of kit
If it's any good to you, I have a cheap ½in router that I've been thinking of getting rid of for for a while... I'm willing to sell it quite cheaply, too (£40 inc. courier?).
It's basically a cheap knock-off/imitation of the Makita 3612C. It's only single speed and it's not as nice overall (I also own the genuine 3612CX so, I can safely say that!). it starts up with more of a kick (like many cheap routers) and is a bit noisy.
It comes with the side fence, a 1/2" collet (might only be 12mm - not entirely sure!), 16mm and 30mm guide bushes and I even have a few cheap (Silverline) straight cutters you are welcome to.
No worries if you're not interested. Otherwise, send me a PM. :)
I have this model but manufactured by graphite 59G715 collet 12mm with reduction to 8mm and something smaller (?) > I newer use that.
1500W 9000-20000 rpm
Is rally good router for not plunge operations.
I would agree that you do need the power of a large router (!/2").
Collets for 8mm shank cutters are available for most of these, and yes, 1/4" shank cutters do complain when cutting deep!
It will save you grief and expense in the long run.
HTH
John :)
