uk1simon":f6mci231 said:
Hello,
I've got a problem with door installation. Don't know how to solve and it seems a bit tricky.
Drywall sticks out a little bit (6mm in one place) and I mouldings won't sit flush. Has anyone come across this problem? What are the solutions?
I attached picture to explain better.
https://plus.google.com/u/0/photos/1148 ... 6478529653
regards,
Simon
Hello Simon,
Stop............ and think!
If rest of the of the plaster board sits correctly on the stud frame behind the plaster board except at one point, then it's probably an obstruction behind the plaster board that is stopping it from sitting correctly on the stud-work. Try pooping a few screws into the plasterboard to pull it back to the stud-work. If this does not work, take the door off the frame, take the screws out and use a sash cramp with two blocks of wood either side of the door frame at the point where the plaster board protrudes, tighten the clamps to pull the plaster board back, then screw back the plasterboard again.
If the rest of the door lining sits correctly, it might just be that the plasterboard needs a few more screws to pull it back to the stud framework.
The above should help to at least reduce the problem to an acceptable level. After which if there is still some protrusion I would score the plaster board and ease it away so the architrave sits properly against the door frame.
Making good is only going to be a bit of paint and filler and you should be prepared for that if you are fitting new architrave so don't let it phase you.
PS: I do this sort of thing for a living.
