Video of machining cleverly done
Interesting but surprising too. I would have thought it relatively simple to set the capture frequency of the digi vid cam to the rpm or a factor of that, with an adjustable time offset/delay to synchronise with the flat of the turned piece.
Also a bugbear [no pun intended] of mine is the phrase 'rate of speed' (hammer)
The extreme accuracy of the synchronisation over an extended period implies that this video isn't done by setting two frequencies (lathe and camera), to be the same, but by some actual explicit sync mechanism.
BugBear
Just a set of "points" mounted on the chuck like the ones in cars/bikes etc.
I have to say it does make my Holbrook look old fashioned :)
monkeybiter":35re368w said:
Photo switching from a reflective spot on a wheel on the spindle as in spindle speed indicators.
Yeah - that'd sync 'em, assuming the camera can take the feed signal.
BugBear
