Venting shed walls
Max Power
26 Mar 2007
County Durham
I'm constructing my shed as per Mike G, but I've got 1" finished t&g v jointed boards which I'll be fitting vertically onto 1" horizontal slaters battens, how would I achieve ventilation between them and the breather membrane ?
One option would be to use a vertical batten on every board at the nail line, but that's going to use an awful lot of battens ?
MikeG.
24 Aug 2008
Essex/ Suffolk border
That would work":2t34xc1n said:
Counterbatten. Vertical battens over the membrane then horizontal battens over them.
Correct. The counterbattens are against the structure & membrane, and ideally, the horizontal battens should have a sloped top edge draining water inwards such that it isn't trapped against the back of the cladding. This is going to affect the vent design at the bottom, the eaves at the top, and the relationship between the bottom of the boards and the plinth. I'd be fairly relaxed about having slimmer counterbattens, if this helps (not the battens, though, as they'll need their thickness to take the fixings).
