cagenuts
I recently bought a Ryobi contractor table saw and decided to put it together today. It has a 5/8" bore and I bought a new rip blade (24 teeth) which has as standard a 30mm bore but comes with a reducer washer.
So I removed the retaining nut on the saw, then the outside flange and inserted the blade with the reducer onto the arbor. The problem is that there is a recess between in the middle of the two flanges which is wider than the reducing washer. This means that I can't get the blade to stay in place properly. What I've now done is to duct tape the reducing washer in place which now allows the blade to sit properly in place whilst I screw back on the outer flange and retaining nut.
Is this normal procedure or do I need some other sort of washers?
Input is appreciated.
Thanks.
Thanks.
