use of record 044 plane for grooves
Col
30 Nov 2012
Romsey
Hi,
My first project using this plane involves creating a 1/4" groove in stiles and rails for a cupboard door.
I started at the far end of the stock, not taking an excessive shaving per pass but still found it difficult to keep the plane absolutely square to the side of the stock. Net result was a groove on a slight angle and a bit wider at the top.
I was able to make a door but had some extra planing to lose the twists in the stiles.
Any guidance to the knack for getting more accurate grooves would be appreciated (or will this just be something that only improves with lots and lots of practice)?
Col
Try adding a deeper wooden fence onto the metal fence, using the screw holes provided for the purpose.
Also, find a candle and use it to scribble over all the surfaces of the plane (and fence) which will touch the wood - that makes it much easier.
Andy - thanks for that - I'll try them out ... Col
Col":1gwwj58j said:
Hi,
Col
Here's some helpful stuff:
http://www.cornishworkshop.co.uk/combihow.html
BugBear
Col
One of the downsides of the 044 (and several other similar planes) is that there is only one skate to act as the sole of the plane and (unlike the old wooden ploughs) it's off to one side. So the tool is quite likely to lean over a bit, as you have found. The other usual advice that I forgot to add is that the right hand should only push and the left hand only steer.
Hi Col
Whether you are planing a rebate or a groove, the easiest way to ensure that you obtain square edges is to add a wider and longer fence to the plane, set the edge of the board against the side of the bench, and then use the side as a guide for the fence ...
Another way is to use a sticking board.
I've just uploaded an article to my website for an adjustable version of this. In this I demonstrate grooving really tiny drawer pieces. If you can get accurate results on these, you can get accurate results on anything! :)
http://www.inthewoodshop.com/ShopMadeTo ... Board.html
Regards from Perth
Derek
Some very useful advice on those posts above.. Thanks.
Another four weeks and I am going to try using those tips.
ac445ab":1v1bgqez said:
Hi,
I just did a video (subtitles in English) using my Record 044. It is my preferred tool for grooving.
http://woodworkingbyhand2.blogspot.it/2 ... -hand.html
Hope this helps
Ciao
Giuliano :D
Guilano - enjoyed the video - I wish I'd seen it before my first attempt! Also, I was very impressed with your collection of planes in the introduction! ... Col
Regards from Perth
Derek
Derek - I've added the extra deep fence and it has helped considerably. I'll remember your link for a shooting board since I'm sure I'll need one soon! ... Thanks, Colin
thanks to everyone for the hints and tips.
I have just finished grooving my second door (over 6 metres of 1/4" groove for the stiles and rails of a full height wardrobe door) and the results are significantly better as you can see from the photo :
Col
