A
Anonymous
Guest
Hi all
Well, after a few days of play I can report a few more things about this saw.
I decided to add the side table on the left rather than the sliding table for now - meant a huge garage clearout which was actually quite enjoyable (especially the huge space I now have )
The left side table gives me an additional 300mm of working area (more than the xcalibre :wink: :lol: )
I made loads of cuts with the mitre gauge and quite a few with the fence and I can only say that I am more impressed as the days pass. This is a very different world to the Kity, and I was very impressed with that.
The cuts simply feel more 'accurate' and precise. the mitre cuts are spot on and I feel more confident when taking them. The repeatability is astonishing from fence and mitre. I cut a few pieces using the scale on the fence and then later reset for another cut and it was dead-on. Not close.
I suspect my whole methods of work will change with this saw
Think I'll grow a beard and buy a new shirt :lol: :lol: :wink:
The only other thing I have seen that disappointed a little is the small size of the fine adjuster knob on the fence is a little too small. One would have more control with one 2-3 times larger - might just make a new one
** the left side table was slightly bowed along its length by maybe 0.5mm at each end. I simply bolted the two middle fixings with the centre part level with the main table. I then nipped the two outer bolts, placed an offcut on it and tapped down until the ends were level. Tightened all bolts and it is dead flat.
