For the outside of the item you are turning try using the cutting edge of a wing of a roughing gouge, but with the gouge turned almost upside down, so it is kind of like a skew chisel. I find you get really nice finish on soft woods doing this. Having the rounded bottom of the flute facing up means you cannot get a dig in, which would be a risk if using a conventional skew. The angle of the grind also makes it easier too.
The inside is more difficult, lower the height of the tool rest, and use a shallower grind. Again you can rotate the angle a bit to try and get more of a slicing cut. I find that using a really small 1/4" gouge works well, the grind I use has wings at 90degrees, rather than swept back. I then use the lower part of the wing and part of the bottom to get a slicing cut.
Best thing though is to turn Tulip wood when it is still wet (I realise it is a bit late for that now!).
Regards, Andy.
