Newb here so apologies if this is something obvious but I wanted opinions on a wooden plane I bought at the w/e which has a lead weighted nose.
The plane in question is a 22" wooden try plane that I found in a Hastings junk shop on Saturday for the princely sum of 3 quid. Would have been rude not to, so I struggled home with it in my rucksack. No obvious maker's mark showing and it was thickly encrusted in places with nasty sticky black gunk (more 'pitch' than 'patina'). Also had a wobbly handle and a loose throat repair patch - but otherwise felt generally sound and surprisingly heavy. I've been wanting one this size as a 'user' rather than a display-piece, so decided to scrape and sand off the crud and see what was underneath.
Once I started cleaning up the nose, made two discoveries - partial maker's mark and address (Charles Nurse & Co at 182 & 184 Walworth Rd, which dates it firmly to 1887-1908) - and a perfect circle of lead, smack in the middle. Closer inspection revealed that two little shiny spots on the top were not nails as I thought but more lead. Presumably, at some point in it's history, the previous owner of this plane (M C Baker) drilled a ~3/4" hole a few inches into the nose, plus a couple of small air-escape holes in the top, and then poured molten lead in to make it heavier.
I can only assume Mr Baker wanted a heavier plane for some reason (it weighs around 6.5 pounds) - but why? Was this trick with the lead a common practice? Not something I've seen before - but then again, my experience is limited. It was certainly a well used tool and the previous owner may have been a bit 'toe-heavy' in his technique judging by the wear; the body is about 3/4" deeper at the heel than at the toe (which raises the possibility he weighted the front to restore the plane's balance?)
Anyway, it's cleaned up a treat. The Marples Hibernia iron is in remarkably good condition and nice & thick. It was previously ground to around 40 degrees, so I reground to nearer 25 then sharpened & stropped as best I can. Needs a little more fettling but cuts beautifully already. Only thing still left to do is to re-glue the throat insert and flatten the sole, then it should be good for a few more years. Not bad for 3 quid and a little elbow grease. Incidentally, the TATHs website has a copy of the 1902 Charles Nurse & Co catalogue, which shows this model on pages 77-78 as "Trying Plane No. 684" plane, which retailed for 7/- (nearly 2 days wages for a London carpenter at the time.)
![Nurse_Pre.jpg Nurse_Pre.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/89/89833-Nurse-Pre.jpg)
![Nurse_LeadNose.jpg Nurse_LeadNose.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/89/89834-Nurse-LeadNose.jpg)
![Nurse_detail.jpg Nurse_detail.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/89/89835-Nurse-detail.jpg)
![Nurse_cleaned.jpg Nurse_cleaned.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/89/89836-Nurse-cleaned.jpg)
