I know this post has been dormant for some time now but as I have just bought one I thought I should air my views.
I was a bit sceptical about the 26mm top but even with my DW625 hung from it the table top and insert remain flat. Putting the whole thing together was simple and the instruction booklet is clear and easy to follow. The fence is a substantial aluminium section with adjustable laminated MDF cheeks and is easy to fit, adjust and remove. The 6.5mm aluminium insert plate comes with 2 insert rings and has seven grub screws to allow easy levelling. One tip is if you are going to use the 4 securing screws, set the plate fractionally high then tighten them which will bring the plate down level. The no volt release switch is good however I would have preferred one with a large flap over the Off switch so you don't need to look at which button you are pressing. The mitre gauge has a small amount of play in it (as usual), I fixed this by wrapping PTFE tape around the guide a bit at a time until I got a snug fit. The featherboards, finger guard and push stick are well made and fit well. I have the fence mounted dust port connected to my SIP dust extractor and this seems to pick up almost all of the dust, I was thinking of building a dust box to go underneath but I will hold off for now. I have spent a few days just playing around with various materials and cutters and have had good results. I made a raised panel door last night and even with those big cutters in the table performed very well.
Overall I am very pleased with this new addition to my very small workshop.
"I love the smell of sawdust in the morning"
