Toy Boat WIP
speeder1987
2 Apr 2012
Hampshire
So yesterday I started making a toy tug boat for my partners nephew and I thought I would put together a WIP. The boat design is from the following book and the design seems relatively straight forward
http://www.goodreads.com/book/show/2305715.Making_Heirloom_Toys
The boat is going to be made from a piece of sycamore I've had lying around for a while, with the mast and chimney made from some walnut as contrast.
The first stage was to resaw and dimension the sycamore which I did by hand, hopefully I will only need the thin part:
In order to cut the rebate needed I printed out and glued a copy of the top down plan onto the wood. This meant that I would be able to position the rebate correctly and then cuto out the outside hull
I then started cutting the outline of the boat on my bandsaw, however after doing one pass I realised I should have routed the rebate first, for the maximum stability for the router. So I stoped cutting the outline and routed the rebate. I hogged most of the insde out with my power router:
And then cleaned it up with chisels and my stanley router plane:
I then proceeded to cut the ouline with my bandsaw
Finally I sanded down the sides of the hull and most of the top except for th back, as there is still a marking on the paper there where a hole needs to be drilled:
Hopefully I will finish the other parts this evening
John
Right, i've almost completed the second part of the cabin:
So I used the same approach as before, I stuck the plan to an offcut from the hull
I planed the back of the cabin to give a nice finish as I won't be able to get to it very easily once its stuck to the lower cabin, the quangsheng block rebate plane makes easy work of this:
I then stuck this to a second offcut
The blank was then to size and then cut the curve on the bandsaw
This was then sanded
Finally the first couple of portholes were routed. I will do the final four tomorrow, its getting a bit late and I don't want to disturb the neighbours!!!!
Finally a picture of what the tugboat will look like, its starting to take shape:
All I need to do now is the cabin roof and the final four portholes. Then the chimey which I will turn on the lathe from ebony, and then three masts which will be from walnut.
Still undecided whether to paint a couple of the parts such as the cabin roof to give some contrasting colours
John
The nephew will love it and want a a whole fleet of them. A good quality oil finish to bring out the grain would be my choice ,you can always paint it after if you dont like the look.
Ohh ships and boats have funnels not chimneys :mrgreen:
Yeah that's what I'm scared of!! I've got some hard wax oil which I'm planning to finish it in. I think I will go for the using just wood as opposed to paints, maybe just a little bit of colour for the cabin roof.
Although we adults probably prefer the natural grain, I think children would appreciate vibrant colours
John
adidat":23sspugw said:
Random Orbital Bob":23sspugw said:
Does wip stand for work in progress?
yes!
nice idea!
adidat
Thanks, I can't take credit through, was reading the book above and just thought this looked brilliant!
waka":23sspugw said:
Going to be a nice looking boat
I hope so, I'm more than happy how's it come out so far :)
andersonec":23sspugw said:
Next one will be life sized John, then you'll be off down the Avon.
Andy
Don't tempt me andy!!!!! :p
John
Time for the next update, I managed to get some work done on the boat today.
I started by making the roof out of a piece of 8mm maple. I cut it on the bandsaw and then sanded it smooth
The roof was then glued to the cabin. The next part was to turn the masts and the funnel. The funnel was turned out of a piece of ebony (sorry forgot to take a picture), but it was turned to a 3/4" diameter.
The masts were turned out of two figured walnut pen blanks. The masts bodies were turned to a 1/4" diameter. These are the smallest items i've ever turned, but they came out ok.
The two smaller masts were turned on the same blank
Finally the holes were routed and the boat dry assembled
Now I just need to sand everything down to a higher grit and then finish. Hope your enjoying
John
Sorry its been so long, here is the photo of the finished boat, in the end I applied two coats of hard wax oil. This was a really fun project to make and would definately make it again
Its now in the capable hands of my nephew, and so far it appears to still be in one piece :)
Hope you've enjoyed reading
John
