speeder1987
So yesterday I started making a toy tug boat for my partners nephew and I thought I would put together a WIP. The boat design is from the following book and the design seems relatively straight forward
http://www.goodreads.com/book/show/2305715.Making_Heirloom_Toys
The boat is going to be made from a piece of sycamore I've had lying around for a while, with the mast and chimney made from some walnut as contrast.
The first stage was to resaw and dimension the sycamore which I did by hand, hopefully I will only need the thin part:
In order to cut the rebate needed I printed out and glued a copy of the top down plan onto the wood. This meant that I would be able to position the rebate correctly and then cuto out the outside hull
I then started cutting the outline of the boat on my bandsaw, however after doing one pass I realised I should have routed the rebate first, for the maximum stability for the router. So I stoped cutting the outline and routed the rebate. I hogged most of the insde out with my power router:
And then cleaned it up with chisels and my stanley router plane:
I then proceeded to cut the ouline with my bandsaw
Finally I sanded down the sides of the hull and most of the top except for th back, as there is still a marking on the paper there where a hole needs to be drilled:
Hopefully I will finish the other parts this evening
