Hi.
First post because, aside from a bit of fencing and general outdoor stuff I haven't done any woodwork since school (30+ years ago)!
I'm looking at making a pretty simple (famous last words!) stand for my TV and related amps/players/etc. I have rough cut (+5cm) the parts needed in the attached plan from beams like the one in the other pic. The beam is 225mm wide by 100mm deep. I plan to mortice and tenon the legs into the tabletop for lateral strength. The shelves are 1cm toughened glass which I plan to just slide into routed channels.
Some tools I have/can borrow - electric plane, plunge router, drill, belt sander, orbital sander, carpenter square, chisels, general purpose saws...
Stuff I think I need - straight edge and G clamps to use as a guide for the router.
I am prepared to buy other stuff, if required, and if it isn't TOO expensive!
My thoughts/questions/musings -
As there is no bottom brace between the legs it seems to me it's vital that the cuts at the top of the legs (and of course, the bottom ones) are absolutely true so the legs are not skewed. Given I have limited tools, what is the best way to achieve this? Circular saws/mitre saws that handle 100mm wood seem VERY expensive!
I planned to join the beams along the long edges with dowels and glue. Is this enough? I figured if I used beefy enough dowels it would be fine... I found 16mm fluted dowel rods online, and if they were, say, 100mm long, would that do? Or should I use a broom handle!? :wink:
I don't want the mortice to go all the way through, what is the ideal depth given the size of wood... 60mm or so? I think the plunge router goes to 65mm.
Although the unit is technically "furniture", I'm not fussed about a few trivial flaws, in fact it would probably add a bit of rustic charm. As long as it's basically sound and true, that's the main goal!
Thanks in advance for any advice!
A.
A.
