Tool Box
DiscoStu
24 Mar 2014
Lee on the Solent
I recently dropped a very heavy object on my Stanley tool box and it is no more. To be fair the main box actually survived it was the plastic accessories draws on top that got smashed.
Anyway I'm after new tool box. Just the basics need to go in:
Set of screw drivers
4 chisels
Tape measure
Hammer
And a few other assorted hand tools.
It will be just used mainly for DIY around the house and the odd project away from home - building a climbing wall or scenery!
I've got a few Festool tools and wondered about options. I've seen a systainer with a wooden organiser. Anyone know where I can get this? Any other options?
I used to be able to get a small panel saw and a medium size level in my old tool box and that would be a bonus.
shed9":3ef14huf said:
http://www.fine-tools.com/werks.html
or
https://www.dictum.com/en/tools/woodwor ... =0FHwoUx4g
You can get the Festool systainer and insert here and you can get the plain insert separately if you already have a spare systainer. I had one and didn't get along with it at all - it's designed to house a slightly odd (to me) range of German hand-tools, so not really suitable for what I needed. I made my own set of wooden tray inserts to keep my regular hand tools in, and it works very wel for me - might be something to consider as a little side project??
Not much chance of getting a panel saw or decent-sized level in there though :/
Cheers, Pete
These are excellent quality http://www.amazon.co.uk/Stanley-194749- ... ley+fatmax
They do a larger version too that would likely take your saw if that size doesn't.
I bought a couple for long term storage of woodturning chucks and tools and was so impressed I bought a couple more for other stuff too.
Looking at the price there I'm tempted to have a think about what else I might use a couple more for ! :)
Cheers, Paul
Ive used most types of tool box over the last 35 years for basic handtools but I've found this to be the best so far http://www.amazon.co.uk/Stanley-194231- ... ley+fatmax
I particularly like the fact that every tool has its own pocket so rather that rummaging through tote trays or in the bottom of the box I can put my hand straight to the tool I need. Also it means I can see if a tool is missing if there is an empty pocket, which prevents return trips to pick up tools left on site.
That said I do like the look of the Festool wooden tool holder so much so I bought a large systainer a while ago with the intention of making my own wooden insert to suite the tools I regularly use, though basically this will be doing what the Fatmax bag does only more designed to each tool.
Thanks guys. The systainer insert is the sort of thing I had I mind but doesn't look like I'd get much in it. Might have to make my own. The Stanley box is similar to what I had.
I have the Festool one, but I only keep my Electrical tools in it now, for which it is ideal in my view, didn't get on with it for my carpentry tools though, had to keep taking it out the box to get into the hidey holes underneath.
If you're after Systainer ideas check out this guy: http://www.benchworks.be/mftb.html He has plans for Systainer based tool boxes and inserts. I'm currently building the MFT-C mobile bench, his plans and ideas are top notch.
Sent from my SM-N910F using Tapatalk
DiscoStu":3g7pirnu said:
The Stanley box is similar to what I had. Sent from my iPhone using Tapatalk
The one I linked to is a top quality, robust box, worlds apart from the cheaper flimsy models with lids in the lids that Stanley and others also make.
Cheers, Paul
The Mrs got me one of these. http://www.ffx.co.uk/tools/product/Stan ... Tool%20Bag
for christmas. I was a bit dubious at first. But actually it's great. I keep my planes and such in the middle. Loads of little pockets and straps secure my squares and so on round the edges. There's a strap for a level which works just right for my saws. When I finish in the shed I bring it up to the house and sling it in a cupboard in the kitchen so I don't have to worry about damp or thieves. Not a toolbox obviously and it could be improved with a dust cover. But if you want an alternative for a selection of specific tools that's easy to move it's great. Waterproof base and so on.
Have I got this right?Here we are on a woodworking forum and we have an enquiry about which plastic toolbox to buy.
Yes! I don't want all the extra weight of a wooden box and I don't really have the time or inclination to make a box. I've got more important projects.
I like the black hd 26" contico tool boxes they are imported from the US and there is a seller on eBay that usually has them. They are good quality and the tote tray runs the full length of the box something that annoys me with the Stanley boxes is the short tote. I'l see if I can find the sellers name
My last box had a full length tote (Stanley) and it was good but you had to keep it reasonable balanced or you'd pick it up and it would tilt and if it was badly unbalanced everything would tip out.
Ended up buying the Festool tool box, plus a sys2 to go underneath and a sys 1 with the containers for screws. Seems to all be very good and ideal for my needs.
This is my site box, it works and is easy to move around with the long handle and wheels. I can get 2 cordless drills in the bottom too. First thing I did was put some 3" hinges on it and a couple of chains to stop it opening too far. I've had every concoction of bag and box and feel the best way is to buy a robust base, make good any weaknesses, and customise it to suit your needs. I've had this a couple of years now and haven't seen them for sale for ages but this is something similar. http://www.screwfix.com/p/stanley-promo ... 238674#_=p
How much if you don't mind me asking?
I don't mind! The tool box was around £25 and the sys 2 about £30. I think the screw box was around £40. But basically the tool box solution was £55, which I didn't think was too bad for the size of it and conscience of the systainers to match the rest of my kit.
Have you been able to source the adjustable legs he uses in his plans?
