Titan vs Sip Planer Thicknesser
brianhabby
24 Sep 2006
Colwyn Bay, North Wales
Hi everyone,
I have been looking at small planer/thicknessers of which there is a wide range from which to choose.
Most of these small devices appear to be almost identical, the two main differences that I can find are the thickness of wood that can be thicknessed from between about 6" at 8" and the power of the motor.
The thickness of wood that can be handled is not so much of an issue but I believe the motor power could very well be.
The SIP model has a 1500 watt motor while most others have 1250 or even less. However, I have just seen the Titan from Screwfix which has a 1500 watt motor and at £149 is half the price of the SIP model at £299.
I know you tend to get what you pay for so what (if any) are the differences between these two machines? Does anyone have either of them and if so what are your recommendations?
Any and all comments and advice welcome as always.
Regards
brian
Both will be loud enough to wake the dead as both will be brushed motors. If you have the space and can get the extra cash is recommend going up a level to a basic induction model like the Metabo HC260.
That being said I was previously in a position where I didn't have space for anything bigger than a bench top machine and ended up with the Titan. The SIP and Titan along with numerous other clones will come from the same factory in the people's republic and are just built to varying specs for each brand.
Of the 2 you mentioned I would say get the SIP. The fence on the Titan is utter junk as its nothing more than pressed steel that's has a lot of flex in it where as the SIP machine looks to have an aluminium box section type fence which will be better. I did pick up one of the aluminium box section fences from clahs olsen as a spare part and tried fitting it to the Titan but sadly it didn't work as fixings didn't line up and there was no sensible looking way to drill and tap new ones.
both will do the job but will need fettling to get the best out of them.
I have the Titan and for the money it's great. It has been used for 30 minute sessions without any issues and it is is easy to flip from planer to thicknesser mode when needed. It is VERY loud and ideally needs a chip extractor if you haven't got one already, I have used my Henry hoover on it but it was full within a few minutes but coped well apart from that. I do push mine quite hard, and it just keeps going which you can't ask much more of for the low price. I can't compare it to the SIP but I can't imagine it's too different apart from being slightly larger.
i have the woodstar
utter carp
noisy as hell
but i will keep it until I am desperate for a decent one
Steve
I'm with Petey83. If there any way you can afford one of the ***260 machines (there are many distributors - all much the same but different names and livery) you'll be far happier.
I have the SIP one. I don't use it much but it does a good job when I do use it. It is very noisy and it's a machine that I limit its use to sensible times of the day! I would love one of the 260 type clones but I cannot give one the room or even justify it. The sip sits under the bench and is only brought out when required. It's bloody heavy and not realy I the portable category, at least not for me, but I just lift it (chin in, back straight etc.) straight on to a portable bench, use it and put it away. Not used a lot but brilliant when required.
Thanks for the replies, most helpful.
Petey83 & RogerP, I understand about the noise but a small bench top machine it has to be as I do not have room for the larger ones in my small shed/workshop. It's a pity no one makes a small machine with a quiet motor, Axminster did it with their TS200 & TS250 (I have the TS200 and it's great).
Cost is also important as I do not have a lot of spare cash to play with.
Regarding the fence, that's something I hadn't picked up on, I wonder if the pressed steel one could be beefed up in any way.
I have a friend who is also looking for a similar machine and he was going to buy the Titan simply on price. I persuaded him to wait until I had done some research online, although I suspect he will go for the cheapest one anyway. If he does, I may wait and see what his machine is like before I take the plunge.
Incidentally, I do have access to a Metabo HC260 at the Men's Shed but can only use that on days when others are around (we have a policy in the Shed of no machine use unless at least two people are present). I want something I can use at home but with not much space, it will have to be one of the smaller machines.
regards
Brian
I have the Titan on the grounds of how often I use it and cost. Have done a mod on the fence as shown plus handle extention shown. To enable me to use the nilfisk wet and dry I have I fitted a wood plug with 35mm hole,works brilliant.
I reset the blades just level with the outfeed table and it works great. Did have a problem with snipe till I redid the blades .
Bought when it was on price reduction so for my needs it's great.
Thanks pops92,
Interesting mod on the dust port, as long as you can suck the stuff away from the machine I don't suppose it matters how you do it.
I have been looking at the issue with the fence on the Titan as that seems to be the main bugbear with this machine and the only significant difference between the Titan & SIP. I know the SIP can thickness a thicker piece of wood (8" as opposed to the 6" of the Titan) but I doubt that will ever be an issue for me.
I found a couple of YouTube videos showing a new shop made fence that seems to work quite well:
Marius Hornberger
Cosmas
regards
Brian
brianhabby":i5mvsmwp said:
Hi everyone,
I have the Titan. It is a better planer/thicknesser than no planer/thicknesser. That's about all that can be said about it. Most of the others in the price range are just clones of the same basic design. I think the best clone I've seen (because of its fence) is the Cotech branded one from Clasohlson:
http://www.clasohlson.com/uk/Cotech-Pla ... er/18-3029
They are all as noisy and as basic as each other though. I've never had much of an issue with the tables on mine though.
I think I'll end up switching to the Metabo/Recordpower clones that weigh in at about 500/600. You get an induction motor and a half decent face with these.
brianhabby":2og91tpn said:
Thinking about the noise that these machines make, does anyone know if it's possible to fit a quiet one?
regards
Brian
Anything is possible. An induction motor is going to be a lot bigger though and you would probably have to play around with the (flimsy) plastic gearing to match up feed rates and cutter rotation rates. Major surgery I'd say.
The noise these things make is often drowned out by a decent chunk of hardwood being chewed through the machine anyway.
You could even get a helical head machined up for it I suppose... by the time you've done that you may as well buy the Metabo.
Would just like to vouch for the Titan, I primarily use if for thicknessing so I've no cause to complain of the fence as I don't really use it but yeah it could be better. However for thicknessing mine has been an absolute workhorse, I would say I've run thousands of feet of mainly softwood through it + a fair bit of oak and it has not faltered once, often using it for a couple of hours at a time. Obviously have gone through quite a few blades, but blade changing is actually fairly quick with the supplied jig too.
Couple of things - I took the blade setting bolts that tighten them onto the cutter head and binned them - having had most of them round off with not too much force I replaced them with better quality ones, much better and didn't seem to throw the balance out or anything.
I didn't have an extractor at the time and it got annoying having to wind the table up and down each time as it has a killswitch type deal whereby you have to have the extractor adaptor mounted on top/underneath for the machine to actually turn on, so I pulled the side cover off and just made a little catch to sit over the mechanism to override that effectively - I'm not advising anyone to do that, but it made my life easier as I can switch between planing/thicknessing at will. Alternatively, use a drill and a flathead bit to raise/lower the table for quick changeover.
Don't take too much off in one pass and it *should* see you well, mine has so far :)
I am upgrading to a Sedgwick or similar but will be keeping this for small stock.
Sorry for the essay! Chris
Here are the Titan dimensions compared to my Kity 439 (induction).
808x442x464 (32kg)
960x570x430 (41kg)
To be fair, price is significantly different but I'm just talking about the space issue.
If I had to have a brush motor then I'd probably try the Titan over that SIP for the money. Having used a brush motor thicknesser I would never go back because of the noise, unless you are using it in an industrial estate.
I do like titan as a brand for simple tools (leccy chainsaw, sds drill, hot glue gun and more which I own) but I wouldn't be so sure for something which has to accurately dimension wood.
Does anyone know if anyone will be selling/displaying the Titan one at Harrogate next week? I will be there on the Saturday and if there is any discount to be had might as well take advantage of it.
regards
Brian
The Titan is already crazy cheap (160 I think) Any less and I think I would really worry about what it is made out of
Sent from my MI 3W using Tapatalk
