devonwoody
Earlier this year I asked about angles to create a box with a diamond patterned insert so here goes.
Because I expect to do some sanding to fit pieces together I have chosen a piece of timber that I call African Mahogany, its soft and its rubbish really, it was lying around at a timber yard ready to go into their scrap bin so I begged it.
Prepared the full length on the P/T and then put to the tablesaw to make some battens lengths.
Then got out my new super duper mitre gauge to produce 45 degree cuts, ( I did have to replace the saw plate to a zero clearance for the cuts)
I firstly cut four pieces to rough size and then prepared some maple to create the diamond shaped piece and did a dry run to work out the size of the maple insert.
Glued up the five pieces using titebond but with quite a few drops of superglue as well to each surface, this held the pieces together with hand holds for two or three minutes. I did put those pins in place to stop any drift whilst glue set after removing my hands. It worked.
Had a look at these pieces this morning and not quite perfect, so might put rebated borders on top and bottom edges. Also the timber will not plane nicely, (its sapwood) so I shall most probably have to hand sand at a later date to get a decent finish.
