Through Dovetails for Drawers
Derek Cohen (Perth Oz)
2 Mar 2005
Perth, Australia
This may be old hat to many of you. Nevertheless, while completing the seventh drawer for the chest, it occurred to me to take a few extra photos.
I have described the process I take with through dovetails for drawers in pictures, in some detail (in lieu of a video). The pictorial is here ...
http://www.inthewoodshop.com/Furniture/ ... ails3.html
Feel free to critique the technique and add comments of your own.
Regards from Perth
Derek
Very nice work.
=D>
One tiny refinement that might be worth considering in the future is this.
Here's a drawer with London pattern dovetails. It happens to have a curved, laminated front, but it's one I had to hand in the workshop and the principles are the same.
But if you look at the back things are slightly different. The lower dovetail has a "flat base" so that it delivers a gap free joint with the drawer slip and drawer bottom. For the sake of symmetry I then cut the upper dovetail with a "flat top".
Like I say, it's a small thing. An even smaller thing is that I usually cut the rear dovetails at a very slightly steeper angle, say 1:6 or 1:7 compared with the 1:7 or 1:8 front dovetails, actually for London pattern or needle dovetails I usually also cut the front dovetails at a slightly steeper angle, say 1:7 versus the normal 1:8 in order to ensure they don't end up having a "finger joint" look about them.
    99.3 KB
    73.7 KB
Seeing how the drawer sides are rather slender, which method of attaching the drawer bottom did you opt for? (I see no rebates or grooves)
Nice looking DTs, btw!
Hi Custard
That is a beautiful drawer. Other than the flat dovetails, I am not seeing any differences. What am I missing?
The cut away at the lower drawer front is very appealing. I had thought to do this, but the curves in mine were too daunting.
Here are a few pics from the first drawer I built. dzj, this should answer your question as well.
Drawer minus drawer bottom ...
Front of drawer with drawer bottom (flush with slips) ...
Rear of drawer ...
More details here: http://www.inthewoodshop.com/Furniture/ ... awers.html
Regards from Perth
Derek
You added Jarrah veneer to the slip. Will this not, over time, wear a groove in the front blades?
The drawer sides in your second post look thicker than in the initial one.
Is this a design feature, camera angle or something else?
It is a smaller drawer, hence the sides look wider (and if they are, it is by no more than 1mm). - it's the top drawer in the chest. The drawers get wider and deeper as they go down. The drawer in the article is the 7th of 8 drawers.
Regards from Perth
Derek
