greybeard
To learn how to cut/chase thread is one of my aspirations for 2007!
I've watched the Sorby site vid clips, and googled around a few sites, but I'm having difficulty finding reading material that is at a simple enough level for me. Most of it assumes a level of understanding/ability way above mine!
I should explain that I don't have a technical background, so I prefer to read around a topic (sometimes reading quite a lot around!) before beginnning to try and put it into practice.
There appear to me to be two types of tool - one a die-type (? the round bit with a sharp edges on the inside that cut when wound on?) that is done on a stationery piece of work, and one where the pressure/cut is applied directly by holding or passing along a hand tool against the wood whilst the target piece is moving.
I assume the benefit of the latter is it's flexibility of size?, so not restrained to one size (like a die)?
To my un-tutored eye the thread cutting of metal tools and those for thread cutting of wood look very very similar - I'm referring to the inner and outer toothbrush-like looking tools (well, sort of like a toothbrush).
Which of course makes me think that the difference must be in the detail, and presumably something to do with the shape of the tiny cutting teeth? My deduction would be something along the lines that metal is cut pointy, cos you can! Wood thread is cut - say - rounded, for durability/wear.
Can anyone confirm whether I'm making a major error or a minor step forward in understanding the 'mechanics' of the process? In fact better still, can anyone point me in the direction of some reading material?! That would be v v appreciated.
Ta in anticipation
(apologies to mods if I've got it wrong - not sure if this is the right place? I though it could possibly appear in the hand tools section?, or the turning section? But then thought that here was good too?)
Ta in anticipation
