DrPhill
Cyber Heretic
- Joined
- 15 Feb 2012
- Messages
- 1,173
- Reaction score
- 333
Hi all,
I am toying with the idea of making a wooden whistle (hardwood) - partly for the challenge and learning experience. I have some ideas about how to procede, but lack the terminology and experience to express myself clearly. Any help in clarifying my thoughts would be welcome.
My toolset is very limited, so I may need to improvise more than you folks normally would.
What I want to achieve is a tapered-bore whistle. Think of a tube with a hole of non-constant diameter*. I can probably achieve this easiest by getting a block of timber and sawing it in half lengthwise, then forming half of the central hole on each piece of timber, before gluing the two halves back together. Maybe the join will 'disappear'.
*id ~20mm, od maybe 30-40mm length ~ 600mm max
I have used the hole creation technique building a whistle case, see here, fifth picture. I started with two pieces of timber, and could not disguise the join. Professionals probably create one or more special drilling tools for this task, but that is beyond my toolset/skillset.
The original block of timber would be longer than the final tube, so that I could bolt the two pieces together as an accurate reference.
Once the hole has been made I would use files and such to shape the outside of the tube.
So,
- does this seem a feasible strategy?
- should I choose a particular 'cut' of timber (timbers to avoid)?
- what should I use to cut the original timber in half, lengthwise, accurately, flat, straight, and preferably thin (to hide the join later)?
- would it make more sense to cut and bolt the timber, and get it lathed before making the hole?
- or even get it lathed before cutting it open (how thin could a cut be?) ?
- am I mad?
Any other thoughts appreciated.....
thanks in advance
So,
- am I mad?
thanks in advance
