StevieB
Following on from the treadle powered saw in the general topic forum, I got to wondering about blade speed. Although treadle powered saws are geared (large wheel to small reciprocating wheel) I presume the actual blade speed is both not high in terms of stroke per minute and not constant since its human powered.
Simple question then is - does having a higher or lower speed make for more accurate cutting, which is best? I know Gill says she cuts at a relatively low speed compared to other scrollers, personally I use about half speed for reasons of both control and vibration issues on my saw.
Are different speeds required for different applications - thick timber, compound cutting, stack cutting, delicate work? Or do you simply whack the saw on at max and go at it :wink:
Steve.
Steve.
