I am sure many of you have found yourself in the same situation as myself.... You want to be able to process cheaper (than PAR) rough sawn timber and do not necessary want to have to do it all with bench planes or maybe like myself you do not have the space for a sturdy enough work bench in order to do large boards by hand. And as many hobbyist will already know investing in large stationary machines is often not possible due to cost or space.
I am hoping we can get this thread made into a sticky and use it to build a knowledge base of all the cheap (sub £300-£400) generic re-bagged Chinese planner / thicknessers - to detail each brands various differences, strengths and weaknesses as well as common things to check, common faults, tips for setting up and any DIY improvements.
For my part i will get the ball rolling with my recent purchase - the Titan TTB579PLN 204mm.
First up as you can imagine for £149 it has all the refinement and finish of a Soviet era Lada. The planers tables look pretty roughly finished but i cant imagine this will be a problem in use. The actual assembly is pretty straight forward and the fact screwfix have made the effort to write there own instruction manual really helps.
Checking the machine over with a torpedo level and a straight edge showed the tables are parallel although the sides are defiantly not but as they play no part in using the machine its of little consequence.
I was already aware from reviews i had read that the fence was rubbish and indeed it is. There are various ways that you could look to improve the supplied fence of make up a wooden replacement as i have seen on a you tube video. My chosen route was to do a lot of googling for spare parts which eventually thow up that Clahs Olsen do a replacement fence of better quality for their version of this machine. It's £32 and i have just been told it will take 2 weeks to reach me so i will update then.
I have not had a chance to use the machine yet so will update this thread once i have.
