So what would I need to buy to convert my Kity 439 to the Tersa block system? I know I need a block and knives, but does anyone know what I need in the way of the block, is it on a shaft (dia) or do I need one with a what dia hole?
Mike
Mike
My block is 12" but I generally only use about half of its width.OwenRS":2zqud7f6 said:Who's got a wide Tersa block but never uses the full width?
MikeJhn":21yxpxjn said:So what would I need to buy to convert my Kity 439 to the Tersa block system? I know I need a block and knives, but does anyone know what I need in the way of the block, is it on a shaft (dia) or do I need one with a what dia hole?
Mike
memzey":1f7yl26c said:My block is 12" but I generally only use about half of its width.OwenRS":1f7yl26c said:Who's got a wide Tersa block but never uses the full width?
ColeyS1":3scggj6b said:Regarding tip number one, if only one blade is doing the cutting, and the others are merely blunt/knackered just filling the hole, wouldn't the one blade doing the cutting wear out much quicker ? So instead of 4 blades of the same, for example lasting 40 hrs, would one blade with 3 inferior blunt blades last only 10 hours ? Does that make sense?
