Buffing Machine Mops (Wheel)
Mikegtr
18 Jun 2020
Morpeth
New to buffing machine. Is there a difference between using a quality buffing machine mop and a cheap mop?
Material it is made from? I notice the term 'stitched 'mop--are there other types?
Use different grades of mop to build up the finish?
Would you use the same mop for both wood finish and metal? Separate mops?
Like most things good quality is better in the long run.
Where to buy?
If you contact the polishing shop and tell them what you’re planning on using it for they’ll recommend what you need
