I do a fair bit of pattern/template cutting in 12mm MDF, and plan to do a lot more in other woods too.
Currently I'm using a collar and a standard 3/8 twin flute straight bit (because I had one) to plunge through with a hand held router and cut the 12mm in one pass.
I was wondering what Bit you would use for this application ?
I would guess that maybe a spiral bit would work better ? Is this the type used for CNC ? as it's basically that kind of cut that I am doing hand held.
If I use thicker wood/sheet, how deep can I cut, with the correct cutter, in one pass ? I've done 3/4 ply before, and that seemed OK
Rich
Rich
