Tell me how to build the easiest workbench possible
ali27
24 Nov 2009
Guys I need a workbench, but I am not willing to pay 200-300 for
such a thing. So either I need to buy second hand or make on myself.
Now when I think of building a workbench, I think of a flat wood/mdf top and four
legs and that's it. Seeing pictures of workbenches I noticed that there were many
extra pieces of woods, between the legs and in other parts. I am guessing that
just four legs is not enough stability. I have very little tools so I need to make a bench
that is super easy to make. Help is appreciated.
Thanks.
The cross members you see are as you say to stabilise the bench, with out them you will have a wobbly bench in no time.
So the basic bench you can make is 4 legs, each connected to a cross member top and bottom then a nice thick top. You need cross members on all sides not just front and back.
I'd say second hand. I got one, ex school, with two massive record quick release vices for £30. Very solid even if somewhat battered.
Mark
pair of tressles and a firedoor. 2nd hand record vice, or holdfasts for workholding.
If you are willing to do some work to it, but want to spend minimal funds on materials, you could look for used scaffold boards (local to me they are 35p/ft + VAT) and laminate them together and make Chris Schwarz' "English workbench", with firedoor as a flat and cheap top. http://www.popularwoodworking.com/woodw ... -workbench
His book is well worth a read if you are building a bench- there may be other good books on the subject, but this is the only one that I have experience of.
Quick and solid bench ...
Hinge a solid door on the horizontal to a wall at the bench height you desire.
Add any type of legs you like to the front (even fold up types - as long as they lock in place).
The attachment to the wall will keep the top rigid.
Time to build: about 1 hour.
Regards from Perth
Derek
We just built a nice basement bench for a friend out of 8 foot 2x4's. I am not sure what they cost in GB but here they are $1.99 each. We laminated the top together using the tried and test "glued and screwed" method instead of clamping, marking the screw spots as we went so later we were able to bore dog holes without worry. Same for the legs and stretchers. we used a simple shoulder vise screw to fashion a wagon vise and bing bang boom we had a nice little bench with a 3.5 inch thick top in a weekend for around $90.00 and a bit of elbow grease..
I built a very cheap and reasonably good bench from old square fence posts and scaffolding boards. Just mortice the cross peices (ripped up boards) into the legs (square fence posts) and drive a couple of nails throught the joints (pre drill), use glue aswell if you want but no need. For the top I planed the scaffolding board edges flat then glued them, nail this on top (punch nails in, or screw from underneath) then plane the top flat and there you go. I painted the bench except the top with green cuprinol and it looked good. The vice was more expensive than the bench, a record 52 for £20 8) .
I also built a smaller one from some four by two joists I got when I ripped out an old floor.
My formative years were spent at a bench of three boards bolted to three frames of Dexion acting as legs, which in turn were bolted to the floor and the wall. Never moved an inch and still doing sterling service several house moves later. Not pretty, but certainly quick and very minimal tools or skill required.
Regards from Perth
Derek
+1
Workbench essentials (my opinion of course :)):
- the working surface absolutely must not move about when you clamp stuff too it and then start shoving it around (with a plane, a saw, a router, .... etc). A wall is a great stabilizer : my own bench is bolted to a brick wall via its back legs, but Derek's solution does exactly the same job.
- the working surface must be flat. I used the cheapest possible solid-core firedoor as a basis (with some MDF layers on top). Any old warped door won't do, but super-flat isn't too important.
- the working surface must be supported. Again Derek's solution does the job, although it must be done in such a way that the surface doesn't "give" vertically (either by "sagging" over time, or by "bouncing" when you bash it). I screwed some 2x4s underneath to give the necessary stability.
PS: I re-used a knock-down, under-frame from an earlier bench, but it was always very wobbly until I tied it to the wall in the new construction.
PPS: some of this is irrelevant, of course, if you can't/don't want to fix your bench to a wall. In that case you'll definitely need to invest more effort in lateral stability (i.e making sure the "working surface absolutely must not move about when you clamp stuff too it and then start shoving it around" :)).
Funnily enough I've just built a new bench this week.
There is a post with work in progress shots here: New Workshop Build Part 1.
Probably not exactly what you are after, but it always helps to gather ideas from a few sources and then use them as appropriate.
'Adding mass' is always a good idea for stability (fixings to the wall etc), if you dont want to screw anything to the walls then put a couple of sandbags on the lower shelf of the bench (assuming you have one when built) - if the bench is stiff then the extra weight will help reduce movement when your working.
For a rigid frame, use either diagonal braces, or the ultimate "infinite bracing" - sheet goods fixed over the legs (just like the hardboard back that prevent a bookcase from racking)
Achieving rigidity in the normal "timber framed" rectilinear design requires large (expensive) timbers, and decent joinery.
BugBear
Thanks.
Your options are endless, but you could start by making a pair of trestles and use a sheet of 8'x4'x1" ply (Split down it's length) doubled in thickness, or a few lengths of 6"x2" (Glued edge to edge with bread boarded ends) faced with 0.5" ply for your worktop. Simple and inexpensive, but not as simple as providing 4 legs with stretchers linked via mortise and tenon joints or dowel bolts. A saw, hammer, jack plane, pencil, tape measure, square and couple of chisels are all you need if tooling is a limitation.
Thanks.
I'll point out that a bench for stock preparation using hand planes needs to be very stable, since the forces are high. Hand power-tools work doesn't need much more than a sturdy table (work can be held for routing by mere friction, hence the "router mat")
BugBear
My favourite (theoretical) work bench is the Japanese planing beam. Basically just a big beam which is heavy and stiff enough to plane on, or to fix workpieces to in a solid and stable way. Here's a westernised version - lifted off the floor and braced against the wall. I found it here.
The basic trad british bench could be seen as two planing beams separated by the well (to keep your tools and bits in whilst you are on the job) all supported by two frames/trestles etc well braced (typically by a deep front apron).
Or if you only work from one side then one beam will do, with a rail at the back (to close the well) set at same height as the beam so that workpieces can be spanned across.
Everything else is an add on or detail design - vices etc.
One of the worst possible benches is the workmate, on which it is almost impossible to plane or saw (without bracing or other strategies) but they are handy as a mobile holding device, step-on etc. Good place to start thinking "benches" though i.e. not to make the same mistakes!
A work table is a different thing altogether, but the natural thing is to try to combine them. But it's handy to separate the functions, in your mind at least i.e. work table and/or solid beam/structure for holding things stably when being worked upon.
