Steve,
The
UK Woodworking folks will all chuckle but; Are you sure you want a table saw? If you're taking up woodwork 'cos of Norm then I probably can't sway you, but be aware that no saw in your budget range will compare with his Unisaw (? Is that right? I never can remember). Plus, if you eliminate all the dangerous joint cutting (which I would, if I was you, and liked having all my fingers) then it's not such an "all-rounder" as it first appears.
If you want to use a lot of sheet materials like MDF [shudder] and Ply then you'll probably do better with a
good quality circular saw, a custom made straight edge and a cutting table. Take a look
here for the set up I use. It's especially handy if you're short of space. You need plenty of room around a TS to use it properly and safely.
For accurate cross cuts you can't beat the chop saw, and you can get 'em so cheap now that they've pretty much become an essential, IMO.
In the long term, don't dismiss the bandsaw. (All right, you lot. Stop laughing) It'll rip stuff very accurately, will cut curves and will resaw boards to make you less dependant on standard timber sizes for your projects. The two biggest bonuses (boni?) as far as I'm concerned are: it's safer and it's quieter. I'd sooner you took away
all my handplanes than deprive me of my bandsaw. (Take a look at my web site and you'll see this is no mean recommendation)
If I was starting again, I'd get the circular saw and a mitre saw to start with (the best quality I could afford) and save as quickly as possible for a 12" throat bandsaw. Now, what was the question...?
BTW, Clarke stinks. Run a long, long way away. Also, have a hunt in the classified ads in the woodworking mags, your local paper, Ad Trader etc for second hand. The cheap "starter" tools often get sold off after very little use when people upgrade to something better. You might want to think about why that is, and save up a bit more :wink: Anyway, food for thought, perhaps.
Cheers, Jester
