mbartlett99
Hi All
Just gone and bought myself a nice shiny table saw - no name version of the SIP 01332/Axminster 10" - on the web for 500 quid. Well pleased generally but have a small issue; the throat plate has a huge gap inboard to accomodate the 45 degree bevel which obviously plays havoc with cutting laminates.
No problem, make a zero clearance insert I hear you say. Thats where its a little trickly, the existing plate is 3.2mm steel plate and while I could machine up some 18mm mdf (which I have in abundance) the supporting lip on the table will require some serious faffing to machine the 18mm down to 3.2mm around the edge.
I had thought about buying some 3.2mm phenolic sheet to cut up but does anyone have any other ideas?
