Saw blade advice for a ta145 startrite table saw.
samej1987
12 May 2013
Newbury
Does anyone have any recommendations for 230mm/9inch table saw blades.?
The problem i am having is when trying ripping material the blade develops a bit of a wobble and really eats into the workpiece. This is a trend craftpro 230mm ripping blade. This wobble even happens when ripping 18mm ply.
If i use a combination blade then i dont get any wobble, cuts ply very well and cleanly but if it then try to cut some 50mm stock it immediately bogs down and stops spinning. I can make the cut but I'm going so slowly that its a bit ridiculous.
Im really struggling to find anything on the internet, i have looked at thin kurf for lower power machines, dedicated ripping blades etc but im at the point of not wanting to spend £50 hoping something might fix the problem.
Thanks in advance, i will also ask the forum but thought i would try you directly.
James
Inspector
Nyuck, Nyuck, Nyuck!
18 Jun 2006
Saskatoon, SK., Canada
Ripping blades are meant to cut down the length of a solid wood board not manmade sheet goods. Crosscut blade is made for cutting across a board. A combination blade is an all rounder for general use. For sheet goods you should get a blade meant for that type of cutting.
The wobble may be the result of the blade getting hot and warping. Possibly dull, or the fence not being aligned causing a little extra rubbing. Also thin kerf blades are more prone to flexing resulting in a bad cut. If you don't have a riving knife or splitter behind the blade the wood can pinch the blade and create heat, or pinch enough to stop it. Also can result in kickback.
Best advise I can suggest is find a local club and get someone from it or a nearby member from here to come around and look over what you are doing to offer advise.
clogs
just can't decide
24 Jul 2020
Vamos, Crete, GREECE.......
sameJ
the inspector is right....
u don't say what saw u have and it's supposed HP.......is it direct drive or does it have a drive belt....? is it loose....?
bit more info pls........
I have found that even new blades of any amount of teeth are really not that sharp.....
I buy a new blade then get it to our sharper's before use.....they come back soooooo good.....
I have a small Hitachi mains powered circ saw.....the difference in a fresh sharpened blade is unbeleivable....
samej1987
12 May 2013
Newbury
Thanks for the replys, it is a startrite ta145 and i believe the HP is 1.5 I would say the belts might not be on that tight so i might well look at that. I should probably also take a video and im guessing that would give more information than i ever could...
