Table saw for a novice
gazh
New member
1 May 2006
Hi everyone :D been surfing through the forum for a while now and thought id say hello some great articles and advice out here talking of which i am looking to get a table saw in the next few weeks in the 3 - £400 bracket whould be most gratefull for any advice as this is my first one and like to get a decent one
unlike the cars that i buy wich last about 3 weeks before blowing up :?
Hi Gaz, welcome to the forum. Try a search of the archives, you'll get a bewildering range of opinions. There is also a sticky thread on forum members table saws. I have a Triton workcentre which I can recommend, especially if you already have a decent circular saw.
cheers
George
Hi Gazh and welcome :)
You can ask 100 members of this forum what tablesaw they recomend amd you are guarenteed to get at least 50 different answers!
The best advice is this - Your tablesaw is a major investment in your workshop, one that you hope will give you many years of good use. Don't buy your saw to a price, buy the best saw you can afford, even if it means saving up for it.
Personally I like cast iron for its stability and weight, and brushless motors for their quietness, so I own an Xcalibur.
Dennis
Welcome :D
Personally,I like to be able to buy tools from somewhere with good aftermarket support (for spares and repairs),and locally wherever possible.
Axminster are very good on delivery and aftersales,so well worth a look.
What features are you after,and whereabouts are you ?
Andrew
Hi Gaz
Welcome to the forum.
PowerTool":2kt3datk said:
Personally,I like to be able to buy tools from somewhere with good aftermarket support (for spares and repairs),and locally wherever possible. Axminster are very good on delivery and aftersales,so well worth a look.
I would agree with Andrew. Recently, I had a problem with a Jet planer and the service from Jet/Axminster was excellent.
As Jorden says, "buy the best you can afford".
Neil
The same, buy both the extension tables if you can afford it. When I bought mine some years ago, you could buy the saw table on its own, not sure if that's the case now. Recommend also that you buy a couple of decent 36T blades. The one Kity supply is OK but only has 18T - Rob
Can't give you any specific advice as to which model/make to choose but I would counsel against buying anything 'as a novice'. You won't be one for long :D and then you'll realise the shortcomings of your 'novice' purchase :cry: . So aim high and as others have said buy the best you can afford.
Tim
