Table saw blade width
hunter1182
24 Aug 2012
london
I'm quite new to woodworking, i'm wanting to cut a peice of ash so that it has a 1mm wide grove that is 20mm deep all of the way down the length of it. The grove will be following the grain. I'm wondering if anyone on here knows of a blade that i could buy that would have the cutting width of 1mm and would be sutable to cut this groove allong the grain of ash wood.
Thanks for any help,
Martin
Jensmith
19 Aug 2010
Cheshire
I think all table saw blades are minimum 2mm wide. I have a Proxxon saw - the modellers type and even that has a 2mm wide blade so think you might struggle.
A bandsaw would do it though in a couple of passes. Not sure what else.
marcros
11 Feb 2011
Leeds
personally, i would do it by hand. Either a handsaw down to a depth line at each end of the piece, or if you were so inclined, you could make a scratch stock. If it were me, I would be tempted to use something to start the saw cut, eg a marking gauge.
hunter1182
24 Aug 2012
london
I forgot to mention that the piece of ash is 1 foot long, i dont have a hak saw that is long enough. Do they exsist? I would still much prefer a table saw that could cut 1mm thick, i hope they exsist haha.
custard
20 Aug 2008
Hampshire
I'm intrigued,
1. Can you put this challenge in context, what's the project and how does this piece fit into it?
2. When you say a 20mm groove, do you mean you want to cut completely through a 20mm thick piece of wood, or you want a 20mm deep groove in a thicker piece of wood?
Custard
Harbo
In Memorium
13 Nov 2006
Hampshire
How long is the length - most bandsaws won't cut more the 12" i.e. with the piece held vertical?
Could do it with a backed saw of the correct thickness and a straight piece of timber as a guide?
Rod
Steve Maskery
26 Apr 2004
Kirkby-in-Ashfield
The easiest way to do this is to fabricate it.
Rout a 20 x 1mm rebate along the edge, then glue on the other side to make the groove.
You won't find a tablesaw with a 1mm kerf. I suppose you might find a slotting cutter, but whether it wold have sufficient depth to cut 20mm is another matter.
The scratchstock suggested above is another feasible route, I suggest.
Harbo
In Memorium
13 Nov 2006
Hampshire
Well one rather complicated way is the use a 2mm TS blade then cut it down the middle with a 1mm Bandsaw blade then stick the 2 halves together?
Rod:)
hunter1182
24 Aug 2012
london
Sorry i'm completly new to all of this. Its 1mm wide grove that is to be cut 20mm deep, the wood is 35mm thick and 1 foot long (305mm). This grove also has to be as acurattly straight as i can get it, its goint to be placed in the center of the ash that is 25mm wide, so about 17.5mm from either edge.
I cant fabricate it :(
Martin
Steve Maskery
26 Apr 2004
Kirkby-in-Ashfield
Do you mean you don't have the facility or it must be that particular piece of wood?
I think you are left with the tenon saw and scratchstock then.
S
Oryxdesign
30 Dec 2007
Kent, UK
Normally I would suggest a slotting cutter to do this but they only go down to 1.5mm (if someone knows where to by a 1mm cutter use that) so in this situation I would clamp on an offcut for a fence an scrape round with the edge of a 1mm cabinet scraper until I got to the desired depth.
Does it need to be very accurate?
Oryxdesign
30 Dec 2007
Kent, UK
If you wait a bit longer I recon Steve will come up with a jig for the bandsaw, do you have one with a 1' depth of cut?
monkeybiter
23 Dec 2009
doncaster
How thick is a hack saw blade? You could easily grind an old blunt blade as a scraper.
joiner_sim
7 Jun 2007
Staffordshire
I know it's already been suggested and already been said it can't be done. But the best way to do this would be to cut the piece in two, cut the groove and glue back together.
AndyT
24 Jul 2007
Bristol
Just use a suitable handsaw! Make some cuts into some scrap, measure the kerfs, and choose one closest to the required 1mm. Mark the position with a marking gauge, fairly heavily. Start the cut at the far end, lowering the blade towards the work. A piece of tape on the saw will let you know when you are getting close to the depth required.
Grahamshed
14 Apr 2012
Oxfordish
The suspense is killing me. I cannot imagine what needs a 20mm channel only 1mm wide. :)
flh801978
21 Dec 2008
Sheffield uk
I could cut it with a slotting saw in my metalworking milling machine they come in 1mm thickness it'd be slow but it would cut
Ian
condeesteso
10 Mar 2011
Sevenoaks, Kent
Martin
Quite tricky this. Andy is handy (sorry) with hand saws but I would not like to get that cut 20mm deep and dead square, straight etc.
A conventional scratch blade will not support itself that deep, but imagine a basic card/cabinet scraper on edge, fixed into a block and with a fence 12mm from it. I reckon that has potential. And note the 12mm... measure twice remember :wink:
A thin-kerf blade in a bandsaw will do it well (against a good deep fence) but you'll need a big 'un, mine is max 11" but I would totally trust it to do this.
I think we need to understand better what you are trying to end up with and what the constraints are.
FarmerTweedy
17 Aug 2012
Edinburgh
Martin
I'm afraid I can't offer a solution to how to cut a 20mm deep, 1mm wide groove, but would like to point out that there seems a bit of confusion regarding your measurements! You say the groove will be in a face that's 25mm wide, but then say it'll be about 17.5mm from either edge. Surely that would mean it's going on the face that's 35mm wide (i.e. the 35mm thickness you refer to)? Not trying to nitpick or anything, just want to make sure you're clear on what face of the piece of wood you actually want to cut the groove in!
Also, if you're cutting a groove 1mm wide in your wood and your wood is 35mm wide, if it's to be in the centre, the sides of the groove will be 17mm from either edge, not 17.5mm. Again, not nitpicking, just wouldn't want to see you measure slightly wrong and end up with the groove slightly off centre, as in a piece only 35mm wide, a 0.5mm error could be noticeable or problematic!
Good luck with it, hope you find a solution that works!
And I'm also curious as to what it's for!
hunter1182
24 Aug 2012
london
It's to make a folding buck saw, the saw blade goes into the grove once its folded.
Martin
