Took the T/S outside today thought I would have a play with it can't use it in the shed not enough room?
It works beautifully with soft wood, but when I had a go at cutting hardwood i.e. laburnum and iroko?
I could smell burning when I finished the cut, I looked at the ends and there is a black burn mark on each piece
The wood I was cutting was quite thin four pieces of 1/2"x1" clamped together on a mitre sled to make 2"x1" when I put pine on the sled it seems to go through like butter.
This is the first T/S I have owned and dont know if I am at fault or I need a good blade?
If you think it may be the blade can you recommend a good all round blade?
p.s. If I cut hardwood on my CMS I have no problems
Phil
Phil
