The original Mafell blades have been excellent for cutting along the grain. Then I noticed a bit of warping (of just the blade hopefully) which I'm putting down to me using them to cut along the grain for over 3m of C16. Through 50mm thickness, so probably running them to the limit which is generally shown as 64mm.
Doubt they'd have expected anyone to use them like I'm doing. Anyway, so I invested in some Festool blades which were rated for hardwood and I expected this would do the job into C16 (as it's softwood right). Well, they did kindof work ok but after using the first blade I checked em for trueness.
Almost everyone is slightly warped (brandnew) so I contacted the seller in ebay. A large wholsesale workshop/tools supplier who assured me they're not seconds at all and they're replacing them. Replacements are coming from Germany, which leads me to the Milwaukee blades I'd bought from Screwfix just earlier before investing in the Fes.
The Milwaukee (very cheap for a 5 pack), also rated for hardwood and also not giving square cuts. Also made in Germany and also (I only checked afterwards the remaining brandnew blades) slightly off-true. I've tried with various straight edges and I'm pretty certain it's not in my head - though it does feel like it.
Now, the question is - aside from the trueness of the blades which must be a poorly batch issue or something - am I incorrect in thinking that a blade rated for hardwood should be strong enough to cut nicely through C16 (softwood?)?? Other question is, which would be you advice/suggestions to someone (daft enough to want to) use/using a jigsaw to cut along the grain in 50mm thick C16.
I've narrowed it down to (going slightly longer this time) these or something similar to em https://www.amazon.co.uk/Bosch-Professional-Hardwood-Multiplex-Accessories/dp/B09417PV8C
I'd have added the pics of the bad batched blades, but you'll just have to take my word for it
Thanks once again and in advance...
![Winking face :wink: 😉](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f609.png)
