paulm
I'll need to dismantle a large ali greenhouse soon and stack it out of the way for a while and/or sell it on perhaps.
If I remember back a few years ago I did the same with a smaller cheaper B&Q type one and put a sheet of newspaper between each of the panes of glass and then stored them vertically or thereabouts, but had a bit of a problem later with suction formed between sheets and/or the paper being a mess to remove after they got wet outdoors.
Any ideas on best way to store the glass outdoors ? These panes are full size ones so probably about 5' long by 2' so not easiest to store and not cheap to replace !
I recall that when we had our double glazing replaced a few years ago the new glazing units had small blue plastic stickers dotted around on them, perhaps 20mm square and 2 to 3mm thick, to separate the units, and that would do the trick and be easy to remove later but can't figure what to search for on ebay, the various permutations I've tried haven't turned anything up.
Suppose I could use some wood battens or corrugated cardboard or something but suspect I'm overlooking something better/easier ?
Cheers, Paul
Cheers, Paul
