I'm making doors for a sideboard - cherry with wenge handles. Trying to allow for seasonal movement but hide the expansion gaps. My idea is to make a stile & rail panel that functions like breadboard ends. Here is what I mean: the handle is deeper than the rest of the door, so the centre panel can expand into the handle. The frame is standard stile & rail, but the right-hand rail is actually the handle. I will post a sketchup file if anyone cares to look, and attach a few images of the sketchup. It's tricky to describe and even harder to draw. Basically wondering is it likely to work or has it been done successfully before.
The door will be 19mm thick (to work with Blum hardware). The handle is also 19mm thick, and 32mm wide where it meets the panel. It has a wider area for a grip.
My house has a thermostat set at 19 degrees all year round in this room. The house is well insulated. The room has large south facing windows and gets lots of light (the cherry has darkened beautifully in no time). Seasonal humidity changes shouldn't be very large. I have made a 5 foot wide mahogany table that hasn't moved more than a millimetre, then again it is mahogany. Thanks for any advice.
![disappearing-breadboard.jpg disappearing-breadboard.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/66/66062-disappearing-breadboard.jpg)
![disappearing-breadboard-3.jpg disappearing-breadboard-3.jpg](https://cdn.imagearchive.com/ukworkshop/data/attach/66/66063-disappearing-breadboard-3.jpg)
