sparkymarky
Hi all, i have a startrite 352 bandsaw which i bought used around 6 months ago. the bandsaw originally had a 750w single phase motor however at some point in its life the previous owner replaced the motor with a axminster 240v 1100w 4 pole motor (http://www.axminster.co.uk/axminster-ax ... -prod29787).
At the moment the bandsaw is set to run at its fastest speed, the problem i have is when cutting thick stock it overheats the motor. it seems there is not enough torque to drive the band sufficiently.
I have bought a new bandsaw blade (tuff M42 3 tpi / 3/4") and have set it to track perfectly, anything over 4" though and the bandsaw starts to struggle.
should i switch to the lower speed?? if so how would i go about it? are there any on-line instructions?
cheers, mark.
cheers, mark.
