9fingers
Hi Mark,
One check to do when you have time is to run the motor with the blade removed. Firstly when you switch off, you should hear a clunk of the centrifugal switch closing as the motor slows and after that perhaps increased rubbing noise. This is normal and to be expected.
Next run the motor for a long period - longer than you normally would before the thermal cut out opens.
With the motor unloaded, does it trigger the thermal switch and/or get nearly as hot as when it is running the saw?
These test are to try and check if the starter capacitor is being switched out properly. If you suspect the switch, unplug the power, take off the cowl covering the fan and remove the fan blades. Under there should be a dished cover held on by a few screws. Remove this. and you should find the switch.
Keeping hands/kids/pets well away, run the motor and watch the switch. It should open when the motor gets up to speed, possibly with a little spark from the contacts and then re-close as the motor slows down. it is quite safe to run the motor without a fan for a few minutes but NOT long term.
Try that lot and see how you get on.
Bob
Bob
