I've been through quite a few old threads on Startrite motors but none quite match my problem.
My original 301 motor has been making creaking noises, so thinking it may be the bearing in the motor took the bottom wheel/hub off to have a look. Ended up having to unbolt the motor as the front plate wouldn't come off to discover the motor is sealed, no way to get in to check the bearing.
Anyway in the process of disassembling removed two small 25mm screws from the holes indicated in the pic below. When came to put it back together they don't seem to have anything to screw into, the motor doesn't rattle as if any bolts are loose in there. Stood back and turned it on and it seems to run ok. Managed to get some spray lubricant in the gap between the case and the shaft which seems to have improved the bearing noise.
Does anyone know what the screws were holding and if it's safe to carry on using without them? I've had a look and the company that made the motor doesn't seem to exist anymore. Otherwise looks like an opportunity to find a slightly more powerful replacement as some others here have done.
Thanks.
Screwholes in question:
Motor plate:
Thanks.
Motor plate:
