lurker":3l6ioyvm said:
Buy one of these and use the bits
http://www.amazon.co.uk/Sourcingmap-a12 ... poke+shave
I think they will fit but at the price is no risk
I did order one of these (well before Xmas) and it turned up this morning. Initial impressions weren't good (anyone for a "Sopke shave"):
At this point I suspected it might be less Jade eagle and more Pyrite sparrow.
On taking it out of the box things didn't improve much. The blade adjustment nuts are clearly coated in something to make them look a little like brass (they have that fake look like the foil around a chocolate coin). The cap is just a bent sheet rather than a casting.
But, believe it or not - it cut straight out of the box. The grind was at 25 degrees, but must have been done with something so rough it's created lines on the bevel that result in wood looking like it's received the attentions of a Zen garden rake. But it
did cut.
I just had enough time to quickly sharpen the blade and chuck it back together, and... it's really not that awful.
The sole is coated in the same black paint as the rest of the shave, and that means it leaves streaks on the wood, so that needs grinding off, and I haven't checked the flatness of the area where the blade sits, or flattened the edge of the cap.
Here it is in comparison with the #151:
The red cap top left is from this cheap model, and the red cap far left is a replacement cast one from a modern #151. You can see this cheap one is quite a bit smaller than the #151.
TBH for £3 I don't think this is a bad purchase. Once sharpened it's working reasonably well. It might be useful if/when the #151 is too large. At least based on 5 minutes use this evening I'd reach for it if I were in the middle of a job and the #151 blade needed sharpening.
Ironically, the one thing I forgot to do... was check to see if the cap screw fits the #151!
