Stanley 1-12-020 block plane bevel angles
Your "specification" 21 degrees is the angle between the body of the blade and the horizontal, which is much lower in this style of plane than it is in a bench plane.
Normal advice for sharpening the blade for a block plane is actually the same as for bench planes - grind at 25 degrees and hone at 30.
This gives an "effective pitch" of 21 + 30 = 51 degrees which is fine.
Thanks very much - that's what I needed to know.
