Most jigs you can make up yourself,there's no point in buying something that can be made out of off-cuts of sheet materials,discarded when knackered & a new one made up.
Forget about buying a stair jig & router template guides,make your jig up out of 25mm mdf & use a 25mm deep,top bearing 3/4" router bit.
The main advantages of this is,you can actually work to to the riser & thread markings out on your strings & by using the 25mm thick jig you can trench out in two hits(you only need to trench out 12 or 13mm deep btw) the top roller will always run on the jig because of it's thickness.
Less chance of ripping the timber to pieces & less chance of destroying the router bit & router.
I've made quite a few stairs & over the years changed how I went about the machining,the only time I ever used a dovetail bit was to freehand trench the nosings (should be done separate anyway) & to freehand all the trenchings to make the joints tighter when the stairs have been wedged up.
This isn't a plug,I'm a site fixer now,I won't make any more stairs like this anymore,but I don't mind helping out with advice where I can.
A stairs is a stairs,gets you from one floor to another,they're big that's why they can be a bit daunting at times.
rubbish picture,sorry,was taken a while back.
